주요 콘텐츠로 건너뛰기
Released in 2013, the TDK Life on Record A26 is a compact, waterproof, portable speaker with Bluetooth and speakerphone capabilities.
6 질문 전체 보기
Why won’t my speaker turn on?
My TDK speaker doesn't seem to turn on. I’m not sure if the battery is faulty or if the charger doesn't want to work. I can’t seem to find a solution to fixing this problem because I have very little experience in taking things apart. Anyone that can help me by giving me advice on fixing it would be greatly appreciated.
Thank You!
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 3개
선택된 해법
The battery might be drained and needs to be charged. Make sure the light turns red to indicate that the speaker is charging when plugged in. If you are still having issues, go to the Troubleshooting Page to find out more. Hope this helps!
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I have a similar problem. When I plug it in the light does turn red, but I can't I get the unit to come on. For a while it would work only if I held down on the power button for three seconds, let go, then pushed it down briefly. Now that does not work either. The unit simply will not come on.
댓글 달기
The swith welds are of poor quality...
With a weldering iron , you can repair you Trek.
The rubber band is easily lifted ;-)
Edit 02/2018: It's better to change the switch (Left : original Right : new)
이 답변이 도움이 되었나요?
점수 0
댓글 달기
It may not be a faulty button as much as a faulty battery that won’t hold charge anymore. Does anyone know why there is 3 cords out of the battery? White red and black makes me think the white one has another function that stops the Unit working when plugged into power point if battery is faulty.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Elise Howard 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 14
전체 시간: 4,040
