Why is my laptop not turning on?
The device shows no signs of being on. The screen is not on and it will not turn on when pressing the power button.
좋은 질문 입니까?
좋은 질문 입니까?
Hi,
Does the power indicator or battery light turn on when you connect the charger to the laptop?
If there is none you either have a faulty charger, faulty charging circuit in the laptop or a faulty battery.
If there is, allow it to charge for a while then see if you can turn on the laptop. If it doesn't turn on, try turning it on with the charger connected and switched on. If it turns on now you either didn't allow the battery to charge enough or you have a faulty battery.
If your laptop is showing no signs of life and refuses to turn on, use this Lenovo IdeaPad U530 Touch Does Not Turn On problem page for possible causes and solutions.
해당 답변은 도움이 되었습니까?
Hello!
As stated above, check to ensure the power light is on. If it is turning on and your screen is still not responding, it may be an issue with your monitor.
First try adjusting the brightness, the computer could be in sleep mode or the brightness could be so low that the images are simply not visible.
If not, the backlight may be broken and need to be replaced.
해당 답변은 도움이 되었습니까?
24 시간 전: 2
7일 전: 4
30일 전: 19
전체 시간: 2,137
