주요 콘텐츠로 건너뛰기
Samsung Galaxy S3는 안구-추적 기능, 늘어난 저장 용량 및 무선 충전 옵션을 갖춘 멀티-터치, 슬레이트-형식 스마트폰입니다.
459 질문 전체 보기
질문 마감됨
Battery cover wont clip in
Replaced the glass on an S3 and changed the frame. when the back plate is on (the one that screws in) the battery cover won't clip in and there's a gap because of this
does anybody know why?
it's doing it on the old frame as well, and tried a different battery cover
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
If the frame is not the exact one, for example the i535 frame will only work with the i535 motherboard. The motherboards are slightly different but can still fir i would check this first(see below)
https://www.gazelle.com/thehorn/wp-conte...
for example this one is the T999. You find this by taking the model number and remove the first 3 letter and the dash.
해당 답변은 도움이 되었습니까?
점수 0
댓글 3개:
the motherboard fits fine
Double check it may fit fine but there are differences, I fought with this issue before and I am sure thats the issue. what was the frame number on the old one and the new one?
Turns out the frame is defective. just going to replace the frame, i have a frame seperator so it's not an issue
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 64
