주요 콘텐츠로 건너뛰기
2012년 6월 출시 / Core i7 프로세서 Turbo Boost 포함 / 최대 1 GB DDR5 비디오 RAM
20 질문 전체 보기
Solder line in port on audio port's place
Hello,
A headphone tip broke off in my audioport, and after reading terrible advice on some forums I tried the superglue idea to remove the tip.. Resulted in my port being glued together.
Long story short, I found a company who thought it would fix my internal speakers if the audio port was removed from the Logic Board. Guess what, it didn't. It seems impossible to get a replacement part for the audiojack as well.
Now, is it possible to desolder the Line-In port and solder it on the audio port's place in order to fix my internal speakers?
I don't need the headphone jack to work persé, I just want my internal speakers to come back to life.
Greetings,
Marc
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 1개
선택된 해법
schoutenmj, the Line In jack and the Audio Jack are different. Apple part number for the Line in jack is 514-0635 and the Audio Jack is 514-0671. Sure you could always try, but the biggest issues is that you may run into trouble soldering it twice and trying to make it fit. More room for error. If you do want to replace it, you can try and find a new jack or you can get it of an old board. The issue here is that it will require quite some skill to solder it properly. Take a look at the schematic. Pin 1 and pin 2 are normally closed, and open when you insert the jack. So if you remove the jack, your circuit will be open. Try to place a jumper from pin 1 to 2 to close that circuit.
이 답변이 도움이 되었나요?
점수 3
댓글 3개:
Thanks for your reply, Oldturkey03!
Unfortunately, I'm not able to read schematics as I'm a total noob in soldering, but perhaps I can try to find someone who can and place that jumper you were talking about to close the circuit and make the speakers come to life!
Post an image of your logic board with your question. focus on the area where the audio jack was located. Post front and back images so we can show you at least where pin 1 and 2 are located. to add images to your question, use this guide 기존 질문에 이미지 추가하기
I'm not so fond of taking out my logic board myself, I'm not really handy with these small electronics (stuff will break if I touch it..!!)
So I guess I'll just have to find someone who won't and can solder it for me. :P
Thanks for your time and effort, Oldturkey03!
EDIT: I've posted some pictures of the backside, one with dramatically overflash but the holes in my logic board are properly visible there.
댓글 달기
답변을 추가하세요
schoutenmj 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 241
