주요 콘텐츠로 건너뛰기
A wide range of repair guides and support for the consumer-grade laptop computer line by Toshiba.
969 질문 전체 보기
질문 마감됨
UNCOUNTABLE_BOOT_VOLUME ERROR preventing boot
I am trying to get this Toshiba Satellite L655-s5115 into Windows 7. I am getting the UNMOUNTABLE_BOOT_VOLUME blue screen.
I put an Windows 8.1 install disc is, to use the repair feature, but it just hangs after the Windows logo disappears.
I used a Windows Recovery Drive USB, it works. None of the recovery/restore options have worked. I have gone into command prompt, but the f:(which has most of the files) is not accessible. C: has two directories related to booting.
Also, Ubuntu on USB works great, I backed-up the personal files using it.
Sfc & chkdisk both fail for different reasons.
Any suggestions?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 2개
Since the system appears to boot fine from a USB drive I would recommend turning the system off and reseating the hard drive. If it continues to fail I would test the system with another hard drive.
Good advice, I did reseat the drive, no success. Since it is also failing a Windows CD boot, I am not stumped.
I would try a new HHD, but they gave up on it.
댓글 달기
답변 2개
선택된 답변
Since it is booting Ubuntu from USB I would recommend creating a Windows 10 bootable USB drive, however this will require access to a working Windows computer.
https://www.microsoft.com/en-us/software...
You should be able to reinstall Windows 10 with the USB drive with no problem due to the way Microsoft handled the upgrade process. This will also give you a clean install if you choose to format the hard drive during installation.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
This is a great option, and should be very helpful in future repairs. Thanks!
댓글 달기
가장 유용한 답변
if you have the windows 7.1 disk i would suggest doing a clean reinstall.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Unfortunately, the key is not reusable.
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 172
