주요 콘텐츠로 건너뛰기
모델 A1278, 2012년 6월 출시. Turbo Boost가있는 Intel 프로세서, 최대 512 MB DDR5 비디오 RAM
1624 질문 전체 보기
Need help identifying this capacitor
Can anyone please help me identify this capacitor on a 2012 A1278 Macbook Pro 13" (non retina), its near the LCD/LVDS connector. As you can see it has been shorted and is causing the LCD to display no picture, just back light (GPU is fine as it works through an external monitor).
Thanks in advance, any help will be greatly appreciated!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 4
댓글 달기
답변 2개
선택된 답변
nickpit, it's not a capacitor. This is just to answer your question, not to diagnose your logicboard. The component is reference designator L9004 which is a 120 Ohm 1.5Amp ferrite bead, or ferrite choke, in a 0402 package. A Murata BLM15EG121SN1D will be a perfect match.
해당 답변은 도움이 되었습니까?
점수 4
댓글 2개:
Thanks for the info!! Exactly what I was looking for. Do you think it appears to be shorted? The solder on one side is obviously missing and there's burn marks around it. If so would it be worth replacing? Cheers, Nick.
Not sure what shorted it out. The part is somewhere in the $0.20 range, so get a dozen and see what happens.
댓글 달기
I can’t believe I had the same question! This thing shorted out from touching the clip that flips over and secures the LCD connector. Ordering the part now, but just curious, did yours work after replacing it? Everything works on the laptop, except I get no picture on the LCD.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
nickpit 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 11
30일 전: 12
전체 시간: 1,094
