주요 콘텐츠로 건너뛰기
2012년 6월 출시 / Core i7 프로세서 Turbo Boost 포함 / 최대 1 GB DDR5 비디오 RAM
20 질문 전체 보기
Why does my MacBook sometimes not boot up?
Hi,
I am having some very odd issues with my MacBook.
I recently had a problem with the MacBook not booting up. So, I tried resetting the SMC and PRAM, which had no effect. So, I opened up the laptop, disconnected the battery, reconnected the battery and then it booted with no trouble. Everything was then working fine until I then shut down the computer. The next time I came to turn it on, I encountered the same issue. On a disconnect and reconnect of the battery, all was well again.
Any ideas on what I can do to fix this annoying problem would be massively appreciated.
Thanks In Advance!
Scott
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개
What does it show when you press the battery test button?
댓글 달기
답변 1개
가장 유용한 답변
Mayer, as always, is on point.
With the system booted, try following these directions: https://support.apple.com/en-us/HT201585
That should provide some detail to let you know if this is a battery issue, which is most likely.
Also... much like the battery and alternator relationship in a car.... remove the batter and boot with just the power cable. If it works... and booting with the battery alone doesn't, it's likely the battery. Though, you're having intermittent issues, so I'm not sure if you would be able to get definite results.
이 답변이 도움이 되었나요?
점수 3
댓글 3개:
Thanks for the complement. Looks like you can handle this one ;-)
Of course. I don't know if you remember this, but you helped me greatly some time ago in getting my a1260 back up and running. I owe you for that.
Brandon - Helping others is thanks enough. Your check got lost in the mail ;-) Glad you're here.
댓글 달기
답변을 추가하세요
Tekkies Europe 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 0
전체 시간: 246
