My rx/tx light turns red
When I key my mic the rx/tx light turns red. When I unkey it turns back green. I also cannot recieve anything coming in nor can I get out. Please let me know what you think
좋은 질문 입니까?
좋은 질문 입니까?
Your tx/rx light should turn red when you transmit and be green all other times. Your ant light should not light up unless the swr is higher than 3.0; then there is a problem. A common reason for the ant light to light up is that the antenna is not grounded properly.
Check out this page from Firestik for more information on swr and cb's.
If your ant light is on when you transmit, stop using the radio and fix the swr. You will ruin the radio.
Good luck and enjoy your cb radio!
해당 답변은 도움이 되었습니까?
the green light is suppose to be on whe cb is turned on .and red when keyed up.
My RX/TX turns red when I transmit as expected, Have no problem transmitting or receiving, My SWR as Advertised and Antenna light stays off, RX/RT light is green until transmit, Make sure that NB-ANL/ANL OFF
해당 답변은 도움이 되었습니까?
From what I was reading the NB-ANL/ANL help filter out the noise from the ignition system and other working parts of the vehicle that give off background noise. So, why do I turn this off??
해당 답변은 도움이 되었습니까?
I wouldn’t turn off the NB/ANL. It filters out a lot of noise.
Ok sorry don't have an answer I have another question, my rx/tx red when I key up like it's supposed to, but I have mine on cal to calibrate it but the needle doesn't move to cal ... it doesn't move at all for that matter ... what gives !!?
해당 답변은 도움이 되었습니까?
24 시간 전: 22
7일 전: 102
30일 전: 578
전체 시간: 42,629
댓글 1개
Mine does the same thing but no antenna light
Chuck 의
