Why is my temp light on
Why is my temp light on and how do I know if I have to replace the bulbs
좋은 질문 입니까?
좋은 질문 입니까?
esther, to determine if you need to change your lamp try to enter the Service Mode:
Enter the service mode by pressing the remote control keys in the following sequence :
Mute -> 1 -> 8 -> 2 -> Power On
Note : If necessary, re-do steps 1~3.
Lamp life display should be in Menu item #8 Option:All
These are the steps for the Temp Light
Error: When the Abnormal Temperature LED indicator flickers.
Poss Solution:
1. Check whether the temperature sensor connector attached to the engine has been inserted normally into CN305 on the DIGITAL board.
2. Check whether the temperature sensor is normal when both terminals have been short-circuited (connected).
Error:Timer+standby/ LED blinking at abnormal temperature Power/LED blinking at abnormal temperature
Poss Solution:
1. Check that the fan operates when LED for timer, standby or abnormal temperature blinks.
2. Check that the cover detection switch is inserted at CN310 on the digital board when LED for timer, standby or abnormal temperature blinks.
3. When LED for timer, standby or abnormal temperature blinks, check that the lamp cover is properly assembled and that the switch-pressing boss(inside) is not bent.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 104
esther what exact model is your TV?
oldturkey03 의
Its and Samsung HDTV Progressive
esther 의
