주요 콘텐츠로 건너뛰기
iPod Original, Mini, Shuffle, Nano 및 Touch를 포함한 대부분의 iPod 전체 분해 및 설치 안내서.
6220 질문 전체 보기
How to recharge a dead iPod?
2yrs old,classic 30GB ipod , dead after dropping on hard floor 2x, not charge at all, responseless to connection to pc...
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 3개
선택된 답변
Let your iPod recharging during an hour: if your battery is very discharged, you can have a hope.
Also, you can reboot it: press the central and the MENU button during 5-6 seconds (if the lock button is enabled, unlock it).
Else, if it doesn't react at all, the hard drive may be dead (don't forget, an hard drive is very fragile).
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
this looks like a connection has broken inside because of the drop. you may have to open it to check if you are comfortable doing so, or have it repaired (quoted) by a professional
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Hey now I have a ipod 30Gb,classic how can i replace the battery!and where can i get the battery.thanks!
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
lawrence, it is better if you ask your own question and give as much detail as possible. "Me Too" does not work on here. Your question shows up as an answer to an old question that was already accepted. Click on the link on the right hand side of this page "Ask a Question" give as much detail as possible as in what happened and what have you tried to fix it. Good Luck
iPod 5th Generation (Video) Battery Replacement
BTW the 30GB is not a iPod Classic. It is a 5th gen iPod Video. The Classic starts with the 6th gen.
댓글 달기
귀하의 답변을 추가하세요
aagm007 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 1,446
