주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Macintosh LC II는 1991년 저렴한 컬러 Macintosh로 출시되었습니다. Macintosh LC의 뒤를 이었으며 Macintosh LC III로 대체되었습니다. 이들 모두는 "피자 상자" 케이스 설계를 따랐습니다.
Can't boot up my computer
I can't boot up my Macintosh LC II. It keeps trying then it stops with a white screen on the monitor. There are no 'faces' appearing on the screen when it tries to boot. Now after umpteenth times I now get only a dark screen. Interestingley in one of the boot tries I was able to get my open file page but with a frozen cursor. After a few minutes the page disappeared with only a white screen again re-appearing. Can this kind of malfunction be repaired?
Update
I found the battery, Thanks, Ralph
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 2개
Fortunately, I found an easy way of fixing my problem. With the intention of removing the hard disk, I first disconnected the multi-pin cable to it, but then decided to remove it for the next day instead. I re-connected the cable back to the hard disk. Lo and behold when I switched on the power, the computer booted up in normal operation.
Presumably, the problem was an oxidation film built-up on the pin contact(s) over the past 2 decades on my Macintosh LC II. Disconnecting and re-connecting the pins evidently abraded enough of the film surface to again make good ohmic contact.
의
Oh, by the way I want to thank both Marian and Mayer for your interest in helping me out. Ralph
의
댓글 달기
답변 2개
선택된 해법
Replace the 3.6 volt AA battery and see if the problem persists.
이 답변이 도움이 되었나요?
점수 4
댓글 5개:
Thanks Mayer for the battery replacement suggestion. I've taken the cover lid off, i can't find the battery. Where is it located? Thanks. Ralph
의
Here's the PRAM battery you need--just look for it. Good luck. Ralph
http://eshop.macsales.com/item/Newer%20T...
의
It should have a small black plastic cover with a slot in it that pulls off, totally useless part. Just note the positive and negative markings.
의
I replaced the 3.6 V battery, the LC II still does not boot up. Any further suggestions? Thanks. Ralph
의
댓글 달기
Hy, Ralph!
How's your LC? Did you repair it?
I've just repaired mine. The power supply was KO. I found one (not genuine) with +/-5V&+12V from an old computer.
The battery keeps your settings and should not be a condition for starting. (At least at my LC).
All the best!
Marian
이 답변이 도움이 되었나요?
점수 -1
댓글 달기
답변을 추가하세요
Ralph 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 21
전체 시간: 6,182
