주요 콘텐츠로 건너뛰기
마더보드 및 CPU 수리 안내서 및 지원.
165 질문 전체 보기
질문 마감됨
Weird temperatures with CPU
Hello !
I don't know if this is an issue or not but i have a Haswell i5 4460 and on idle i get 30C , with youtube and a few apps opened i have 40-45c and on max load ( I tried Borderlands And Fallout 4 on ultra ) i never got more than 40C , I use HwMonitor , sould i use another heat measuring program or is my CPU made out of magic and doesn't overheat?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Hikary Katsu, those temps look normal , there should be no issues in those ranges.
Haswell i5
Idle Temp 28 to 35°C
Normal Temp 47 to 60°C
Max Temp 72°C
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
I was about to say the same as oldturkey03. The temps sound pretty normal to me. The load temp if accurate is great and you should have a good long lasting cpu if this is the case. You could also try some other hardware monitoring software such as speedfan to see if it reads the same as HWmonitor.
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 3
전체 시간: 84
