주요 콘텐츠로 건너뛰기
6MB 공유 L3 캐시 2.0GHz, 2.3GHz, 또는 2.6GHz 쿼드-코어 Intel Core i7 프로세서 (Turbo Boost 최대 3.8GHz).
580 질문 전체 보기
Why is my MacBook occasionally restarts with a kernel panic?
Hello,
I was dropped My macbook pro retina short while ago. It restarts randomly with a kernel panic occasionally. Screen edge is scratched and blacks at that edge is brightened some...
Macbook is not stable now, i don't want lose my work because that unexpected kernel panic problem. What should i do? Is screen can cause this problem?
I am using OSX 10.9.5 now. I ignored updates after this version because it's stable with my audio engineering softwares... Is an update also can help me?
Thanks for help already now...
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 3개
선택된 답변
I solved my problem... Solution is so simple... I opened my macbook and checked the connector between logic board and screen... It was not well placed. I think after i dropped macbook that connector was taken out. So i replaced this connector and kernel panic problem went away. If someone who encounters a problem like that it is worth a try...
Thank you for all your concern.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
how did you do it though?
댓글 달기
가장 유용한 답변
First, keep your security updates done. You don't have to upgrade the system. Kernel Panics can be hardware or software related. Keep an external backup of your data at all times. Just plug in an external hard drive and it will ask if you want to use it for a Time Machine backup. Install a good anti-virus such as Symantec. Apple is now a target because of their success, no one cares about Bill Gates anymore.
To see if something you added is causing the problem start up in Safe Mode by holding down the Shift key on start up.
해당 답변은 도움이 되었습니까?
점수 3
댓글 4개:
I'm using Bootcamp and Windows 7 is installed as second OS. I having this problem on Windows too. All security updates are done and i'm using Avast Mac Security 2015.
I think there is a problem which originated from hardware rather than software. What makes me think like that is this kernel panic started right after i dropped my macbook. Is screen replacement can be solution for this case? What is your opinion?
Thanks for your concern.
If Tom suggestion is over your head, I'd take it to a Apple Store or ASP and see what they would charge for a Flat Rate Repair as you may have logic board issues.
Hi,
My MacbookPro 15inch late 2013 stopped booting up because of kernel panics. And when I took it to the service center they told me that the logic board needs to be replaced which would cost me around $700. No damage no software failure.. Just out of the blue it started this problem. I have started to question the quality of Apple products now.
Thanks!
Call 1-800-MYAPPLE. Ask about a "flat rate depot repair". It should be $357 including shipping and tax.
댓글 달기
Most likely cracked solder joints under the chips, causing system instability.
You can find the exact module of failure by tracing the panic dumps.
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
Thanks a lot. I'll try...
댓글 달기
귀하의 답변을 추가하세요
Tevfik Ali 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 7
전체 시간: 2,017
