주요 콘텐츠로 건너뛰기
Apple iPhone 5c는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 8, 16, 32GB / 흰색, 분홍색, 노란색, 파란색 및 녹색으로 제공하였습니다.
1233 질문 전체 보기
Smoking charging cord /iphon
I plugged my charger in to charge my phone, the charger started smoking. I immediately pulled the charger out. The charging hole on iPhone smells of smoke and the phone won't turn on nor does it show its charging! Any ideas help please. Already tried hard rest
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 5개
선택된 답변
Uhh..well..hard to say. You'll have to take the phone apart. It is possible you could relate the lightning dock and maybe the battery. It's possible it could be revived
iPhone 5c Battery
iPhone 5c Lightning Connector and Headphone Jack
There are of course no guarantees, after what you've done. So take a look at the board, and see how badly it's been burned. Maybe it hasn't even been burned at all?
iPhone 5c Battery Replacement
iPhone 5c Lightning Connector Assembly Replacement
iPhone 5c Teardown
iPhone 5c Battery 이미지
상품
iPhone 5c Battery
$29.99
iPhone 5c Lightning Connector and Headphone Jack 이미지
상품
$9.99
iPhone 5c 이미지
안내서
iPhone 5c Teardown
난이도:
운영
안내서
난이도:
운영
15 - 45 minutes
iPhone 5c Lightning Connector Assembly 이미지
안내서
난이도:
어려움
45 minutes - 2 hours
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Your charging block may be damaged.
This happens to non OEM. Cords/blocks.
In sum cases I found the power block voltage spiked and sent to much power to the phone and it burned the ribbon cord that connects the power port to the main board.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
My iPhone 5s recently just did that. And the really nothing apple will do. You would've thought as good as they strive to be, they'd be helpful.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I just bought a new one hahah
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
the exact same thing happened with mine ive had so many chargers or my i phone and i got a new one yesterday and i put my phone on charge and realised the charger was smoking so i took it out and there was a hole on the charger , i didnt know what to do so i took it out and waited for it to be cooled down and the iphone sed it was charging, so i just left it and came back to it yesterday and now it wont turn on at all. i dont know what to do lmao
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
darmercer 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 12
30일 전: 49
전체 시간: 14,582
