주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo 프로세서
CPU Upgrade to future intel processors
Good day,
Those the motherboard in the intel imac 21.5" support future iterations of intel processors?
I do a lot of audio work using my imac. I would like to have the option to upgrade the processor and ram (which I know the motherboard could now take up to 16 gigs) as needed in the future.
I would ideally like to upgrade to to the i7 processor currently offered in the 27" model. Is it at all possible?
-Thanks
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Here is a guide on how to remove the CPU
iMac Intel 21.5" EMC 2308 CPU Replacement
As far as upgrading the CPU you the i7 is not possible because the current CPU and the i7 have different sockets. You could try upgrading to a CPU with the same socket as the Core 2 duo currently in the iMac here are the specs for the core 2 Duo.
http://ark.intel.com/Product.aspx?id=414...
To be on the safe side I would probably get a CPU with the same Max TDP (wattage) and voltage range as the Core 2 Duo.
The best LGA775 socket, 65W TDP, 0.8500V-1.3625V voltage range CPU out there is this one:
Core 2 Quad Q9550S (Yorkfield), spec# SLGAE (E0) Here is a list of the CPU's:
http://en.wikipedia.org/wiki/List_of_Int...
This s not an i7 but it will definitely outperform the Core 2 Duo. You will probably have to reinstall Mac OS-X AND OR come up with a driver somehow to accept this CPU since Apple never made a Mac with this CPU.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Edgar Tejada 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 7
전체 시간: 3,084
