주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Kia Forte는 2008년 중반부터 기아자동차가 생산하는 소형차입니다.
Kia Forte with suspension noise on bumpy road
Please listen to below youtube video I took this morning. It feels like the noise is coming from the front wheel on driver side, but not sure. The noise is there only on bumpy road. Can anyone help?
https://youtu.be/KME-VRXgvu4
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
Sounds like a sway bar link is broke. Look at the small rods that connect the strut to the sway bar
이 답변이 도움이 되었나요?
점수 4
댓글 8개:
I just got back from the shop, both sway bar link replaced but the noise is still there.
The Mechanic also suspected sway bar link like you did but I guess that's not it. Thank you for the comment though.
have them check the lower ball joints and the rear motor mounts , the car is really to new for them to be worn yet but I would look there next
question: I have loud clunky sounds. Sears insisted I have a problem with inner tie-rod (right side) but dealership insists it is front swaybar link (left side). how the heck can I be sure which is correct?
thx
Kiragirl
front swaybar link is likely the problem odds are if you look you will actually see that its disconnected . The inner tie rod would cause tire were and you would notice the car feeling a little wondersome. usually not a lot of sound involved with an inner tie rod
thank you, front left swaybar was the problem! all fixed now and drives great. I guess I will only use Sears for very basic maintenance/tires.
댓글 3개 더보기
댓글 달기
Brake rattle! I had a metallic clicking sound over bumps. Dont over think it, take a good look at your brakes. Grease slide pins, replace worn abutment clips, make sure your brake pads have a snug fit but move freely. Use disc brake quiet. It was driving me nuts but not anymore!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Wooran Lee 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 23
전체 시간: 10,417
