주요 콘텐츠로 건너뛰기
Mac Pro는 Apple이 제조한 Intel Xeon 기반 워크스테이션 컴퓨터 입니다. Mac Pro는 대부분의 구성에서 가장 빠른 Apple 컴퓨터이며 현재 Macintosh 제품군 중 세 가지 데스크톱 컴퓨터 중 한 개 입니다.
665 질문 전체 보기
SSD Aura Pro 6G
HELLO-
My name is Colin Camp. I have a macpro using a flash SSD Drive - I think it's a aura pro 6g - it's not the type Flash ssd drive in mac air but close- the connector is slightly bigger- in any event- I need to pull it out of my system b/c lightning hit my house and killed my mac-
I tried to install it in my mac air but like I said- the connector is slightly different so it won't work- I have usb / enclosures which are great for sata drives but I don't have any adapters that will accept these type drives ( ssd- flash ).
is there an adapter / enclosure that I can purchase so I can plug it in to retrieve my data because I'm sure its all there. I wish I had a mac pro similar to this one but I don't= thanks
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개:
Can you clarify the make and model of your SSD (take a picture or two so we can see it, post them in your question using the edit function) Also, please give us your systems serial number so we can correctly identify which model you have. This will give us the needed info to help you.
댓글 달기
답변 2개
Check here: Other World Computing
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
This is what you're looking for:
https://eshop.macsales.com/item/OWC/MAU3...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
collin 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 167
