How do you get the battery out
it wont turn on and i need to remove battery.
좋은 질문 입니까?
Without completely ruining your brand new GoPro, you can't. End of Story.
해당 답변은 도움이 되었습니까?
El equipo esta sellado no podes retirar la misma a mi se me ocurre retirar la misma fresando la tapa trasera retirar la bateria, repararla, lo que tengars que hacer y luego fabricarle una tapa sellarla y hay carcasas para el mismo modelo para sumergirlas a 40 metros de profundidad, no creo que exista otra soluciòn, por lo menos tuve una mejor soluciòn que la empresa Ifixit.
Saludos Victor
해당 답변은 도움이 되었습니까?
You can try freezing with dry ice to make the seal adhesive become brittle so the front and back cover come off easy instead of what is shown in this video where the opposite... heat was used:
해당 답변은 도움이 되었습니까?
24 시간 전: 2
7일 전: 3
30일 전: 6
전체 시간: 1,013
