After repairs display reads 888, what does this mean?
After doing some repairs the washer display reads 888 and won't work. What can I do?
좋은 질문 입니까?
좋은 질문 입니까?
I found low AC voltage (93VAC) also gave an 888 error code, as well as lighting up all the other indicator lights
해당 답변은 도움이 되었습니까?
888 means the PC board is shorted and the display driver that shows what supposed to be a display is not working,I would take the PC board out of the machine,look for water corrosion,it will be like a white puffy kind of stuff,if you see that,you have water damage from some other part inside.Try electrical cleaner but you would probably need a new PC board at that point.Look at all the boards while you are inside the machine.
Make sure its unplugged,dont get electricuted!Very important! If its sears,thats kenmore and thats GE.So you can get parts via Sears or ebay or amazon.Good luck,report back!
해당 답변은 도움이 되었습니까?
Mine displays 888, refuses to drain after dishes clean.
@gail did you ever figure this out?
24 시간 전: 13
7일 전: 78
30일 전: 435
전체 시간: 29,444
댓글 7개
Hi,
888 is not an error code, it usually means that the control board is confused.
At power up It normally scans thru all the switches and sensors to make sure that they are there and as they should be . Having one faulty should give an error code having two is probably enough to confuse it. e.g. if two sensors were connected together electrically by pinched wires. (Not saying that sensors are the problem). Recheck your work and make sure that you haven't left something disconnected or connected to the wrong place, such as sensors switches etc and that you haven't 'pinched' any wiring when you re assembled your machine.
jayeff 의
I have a kenmore he 4t and i have NOT taken my machine apart. I went in the laundry room after the machine had started ok. Later i went back to the laundry room the machine was not running and all the lights were on and whistling with the number 888 lit up. Now my machine does nothing but whistle and all the lights lit up.
variellk 의
Wahou ! I have the same probleme Variellk. I'm using my HipVap and immediatly said "888" error and all light turn on. What can we do for resolve the toubles. Thank you
Yann Viano 의
Low AC voltage also gives a 888 error code.
Bob Green 의
CODE 888:
Comments all suggest 888 always means serious problems, so I must add a comment:
KISS Principle: Sept 22, 2022 delivery of a GE GPT225SSLOSS. Glad I didn't research code 888 when it first appeared. There is no information on that code in the owner's manual, nor the Installation Guide. The code appeared as I followed the Installation Guide Step 5 "Add 2qts of water to the bottom of the dishwasher to lubricate the pump seal." Although it does not say to dump it, I wanted to check winterizing as I was going to take it to my Adirondack island where it sits through each winter. With the dishwasher plugged in and the unicouple hanging in the sink, I pressed Start and closed the door anticipating the 10sec delay, followed by the 60sec discharge of water into the sink through the unicouple. After 20sec, a rapid error audio alert sounded twice and I opened the door to see 888 in the wash time window. CONTINUED:
John Carmichael 의
댓글 2개 더보기
