주요 콘텐츠로 건너뛰기
Digital Pocket Memo with slide switch operation.
Why is my speaker making a crackling noise?
When I try to replay my recordings I can barely hear my own voice because of the loud crackling. This malfunction started yesterday after I accidently dropped the DPM to the floor.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
Vermutlich Anschluss am Mikrofon abgerissen
댓글 달기
답변 1개
The most likely cause of your problem is that the speaker is blown and needs to be replaced. Another reason could be that one of the solder connections came loose or undone. You should check on that before purchasing a new speaker when there is only a little tin-solder needed. More possible causes for your problem may be listed on the Troubleshooting Page.
If you need help on disassembling the device and checking the solder connections please refer to the provided guide for replacing the speaker.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Ecodesign TU Wien 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 5
전체 시간: 1,397
