주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
2522 질문 전체 보기
shield screws mixed up
Hello
Hopefully you can help me
Change an iPhone 5 screen the other day but got the 3 shield screws mixed up. I've got the non magnetic one on underside of the motherboard but could only put a magnetic one on top . Also the other 2 are just random small screws .
How could this affect my phone
Also could I just purchase the 3 correct screws from you
I could buy a bag in eBay but if I got the whole set of screws I'd never know what 3 I needed
Can you help me please
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 3개
가장 유용한 답변
The lower right one is the most important, if you use a screw that is too long you could strip the logic board grounding copper out and be left with a blue screen of death (BSOD) that renders the iPhone useless until repaired with microsoldering.
If you have a digital caliper I would recommend using that to measure the screws, correlate with the iFixit guide on the length and there's your fit.
iFixit doesn't sell the screws in question you need individually, except as a whole bag unit unfortunately. :-/
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Thanks for that
What's the length of those 2 at the bottom. I can at least make sure they are the right length
Thanks
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
According to our guide it is 1.2mm. Fortunately both bottom screws are the same, so as long as you have the upper right correct you're in the clear!
iPhone 5 스크린 교체
댓글 달기
non magnetic is always top right. i would love to know why this is. somebody please tell me, it has been killing me for ages.
whenever you're in doubt just look at what it's screwing into. If that screw is going into a standoff then you're going to want the long screw, if it's going into the logic board then you want the short screw.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
That's because the compass module (chip/fuse/whatever?) is housed there. Magnetic would throw it off :P
I finally have an answer... everytime I remove that screw I ask myself this question. Thank you!
댓글 달기
귀하의 답변을 추가하세요
lee ball 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 1,553
