주요 콘텐츠로 건너뛰기
듀얼 마이크와 802.11ac Wi-Fi 연결 기능을 갖춘 더 큰 Apple MacBook Air 노트북 입니다.
465 질문 전체 보기
MacBook air will not charge after small spill, everything else works.
After a small spill my macbook air would not accept a charge, but everything else worked great. I tried another charger, but same results. I plan to open the mac and clean any visible corrosion. The spill was on the keyboard and none got into the charging port. What would be the most likely area to be the problem.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
선택된 답변
If it powers up from the keyboard and all the keys work, I would replace the I/O board: MacBook Air 13" Mid 2013 I/O Board Replacement
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Only opening and properly cleaning the mac will be the 1st best solution. If a good cleanup does not resolve the problem you'll need find a apple motherboard repair shop capable of repairing circuits in the board if your are unable to diagnose and or smd rework soldering.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
vintagemr 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 124
