Why is the battery light flashing on my roomba?
The battery light and the clean light are flashing the battery light is amber color and the clean light is green but they are both flashing and it does not appear to be charging.
좋은 질문 입니까?
좋은 질문 입니까?
ajfaith1012, by your description it sounds like a problem with the battery charging. Either your battery is bad, the charger is bad, or the charging circuit inside your Roomba has failed. You could start with a new battery and after that try an external charger for Roomba batteries.
해당 답변은 도움이 되었습니까?
Does it take batteries Even though it's charging on outlet
Where's the batteries located on irumba
OK can't find it
Elena Chreene what model is your Roomba?
After trying the standard and much covered Power Reset buttons press (see Youtube.com) I still had an orange, flashing (slowly) battery icon. I did the reset three times and left it to charge overnight. Still no luck, so I unscrewed the bottom plate (how you access the battery) and installed an old but still working battery. My Roomba 655 then ran for 12 minutes, which is the length of the charge that battery holds. I have a replacement battery in there now and it WORKS!
해당 답변은 도움이 되었습니까?
It still does not work it comes up with a error number 0 0 7
Should I order a new battery charger for it
Should I go ahead and order a battery charger for my 665 roboma
24 시간 전: 7
7일 전: 35
30일 전: 161
전체 시간: 27,366
