주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
iPhone 6 locked after screen replacement
iPhone 6 locked after screen replacement. Message appears to connect to iTunes. When connecting to iTunes message on iTunes appears to unlock the iPhone with code. An endless loop.
Maybe an Apple lock when detecting an unoriginal screen? Don't know.
Please help. Thanks
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 8
댓글 1개
is this still the case with changing the 6 screen?
i am just about to change one for a friend?
댓글 달기
답변 6개
가장 유용한 답변
Do the following ONLY IF ALL the following conditions are met:
You are sure that the device does not have Find my iPhone enabled, or you or the owner knows the Apple ID and password.
You have the original Touch ID subsystem (Home button assembly) on the phone and intact.
You are sure that the device was backed up to iCloud or iTunes before, or you don't care about the content on the phone.
Then,
Plug in the cable, turn off the device, press power + home button for 8 seconds, then release the power button but hold the home button until the device is recognised by iTunes.
해당 답변은 도움이 되었습니까?
점수 11
댓글 12개:
Tom, thanks. Worked out just perfect :-)
atta boy Tom. you for real my dog.
Amazing thanks... copied it to the letter and worked perfectly thank you
I keep getting an 0xE8000015 unknown error everytime the phone connects to itunes. When I hold the buttons i only get the apple logo and then it blinks. help i dont want to have to spend another 150 to send it back to apple
not all heroes wear capes but you need one!
댓글 7개 더보기
댓글 달기
Hello,
I'm not sure how this could happen to you. Best it to restore iPhone via iTunes. Basicliy if you cant enter passcode somehow, enter it! If u cant, restore it or put new iOS via DFU or Recovery mode.
Hope it helps, Nikola
해당 답변은 도움이 되었습니까?
점수 0
댓글 3개:
Hi Nikola,
thank you for your answer. I can't enter passcode on the phone. The only screen is the emergency call, and a message "connect to iTunes". Then when I connect to iTunes I get the message "Enter passcode on iPhone to unlock". Not able to get into to the restore menu.
What is DFU?
Why u cant enter passcode? ur touch doesnt work?
DFU mode is Device Firmware Update, its used in case u cant boot properly device or if u need downgrade iOS
The phone is already disabled by too many failed passcode attempts at this point, recovery or DFU is the only way out.
댓글 달기
iphone passcode unlock. You can remove the passcode by restoring your device from iTunes or Find My iPhone if you've turned it on before. The catch here is that you will lose your data by following the above method, so you should be aware of that.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I did tried and it's work well
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I have unlocked iPhone 6s plus after getting it from USA to India, one day screen was broken ,so I replaced it OEM brand display, after a day my phone got locked and it is asking activation is required, Any help can be appreciated
댓글 달기
I keep getting error (9) what dose that mean when it's restoring
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I have the same problem before and the Joyoshare iPasscode Unlocker fix it, so maybe you can have a try, it’s helpful and safe.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
larsthue 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 10
전체 시간: 30,116
