주요 콘텐츠로 건너뛰기
2015년 9월 25일 출시. Model A1688/A1633. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 6, 64, 또는 128GB / 은색, 금색, 스페이스 그레이 및 로즈 골드로 제공하였습니다.
2690 질문 전체 보기
How to get out of recovery mode after updating to iOS 9.2.1/9.3
Since Apple seeded the iOS 9.2 Beta 2, I updated my iPhone 6s to the new system, unfortunately, after updating to iOS 9.2 Beta 2, my iPhone was stuck in recovery mode, no matter how I try, I can not get my iPhone return to normal, anyone who can tell me how to do now, thanks in advance!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 6
댓글 4개
iPhone stuck on recovery mode? Failed to access data on your iPhone. Constantly annoyed by putting iPhone in recovery mode? Here's the solution!
When updating iOS or jail breaking your iPhone, you may probably meet the problems above. iPhone Data Recovery can help you get your iPhone out of Recovery Mode in order to make it function normally in an easy and effective way. Fixing your iPhone without losing data on your iPhone in just one click.
Read the guide from: Fix iPhone Recovery mode after iOS 9.3 update
iPhone Data Recovery and iPhone Recovery for Mac provides three simple ways for any iPhone iPad and iPod touch users to directly restore the lost and deleted data, or extract the lost data from iTunes or iCloud backup with ease. So, you can get back lost iPhone data after upgrading to iOS 10/9.3.3/9.3.2/9.2.1/9 with the help of this software. Besides, you are allowed to fix iPhone stuck in recovery mode/white Apple logo screen/black screen and so on with a click. Hope this can give you a help.
iPhone iPad Recovery Tool is an all-in-one iOS data and system recovery tool which can not only recover lost iPhone data after iOS 10 update, but also enables to get iPhone out of recovery mode/white screen and Apple logo loop with a click.
iOS System Recovery can help you three simple steps to get iPhone out of Apple logo screen and recovery mode:
Step 1. Install and run the program, and choose the repair iOS system feature.
Step 2. Download and select firmware for your iPhone.
Step 3. Fix your iOS to return it to normal.
Read the video guide here: https://www.youtube.com/watch?v=DccyjkYW...
댓글 달기
답변 10개
가장 유용한 답변
Just go to DFU mode.
해당 답변은 도움이 되었습니까?
점수 3
댓글 3개:
Tom, how do you do that?
Plug in the cable, press power + home button for 8 seconds, then release the power button but hold the home button until the device is recognised by iTunes.
Step 1. You should see a pop-up screen asking you to "update" or "restore" the device.
Step 2. You can choose Restore or Update your iPhone to the latest iOS. Remember that the existed data will be erased, and you can choose the latest backup to restore.
https://www.imobie.com/support/put-your-...
댓글 달기
The best way to force true DFU mode, does not involve a 10 second countdown. If you are stuck in a 7 second bootloop for example, you wont be able to get DFU mode this way. Instead you can do this: https://www.youtube.com/watch?v=ASXZHaJo...
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
If you get an error during the restore, post it here
댓글 달기
Hi Todd,
I think i understood what your problem is,
1. Download iRec
2. Extract > Open folder > EXIT.
This has worked for me like 100 times. If my solution works for you then gift me an iPhone ;)
Regards,
kksilvery.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Restore it trough the DFU mode. Home + power for 10 seconds, release power and keep pushing the home for 5 more seconds. Everything with your cable plugged into the Mac/PC and keep the iTunes running. After that just click restore in the iTunes.
해당 답변은 도움이 되었습니까?
점수 0
댓글 3개:
I have tried this and am still stuck on the connect to itunes screen and cant do anything with the phone
I performed a 6s screen replacement yesterday. Afterwords, the screen read "iPhone disabled connect to iTunes." I couldn't do it on my laptop. I had to do it on the clients laptop I which she restored the phone only once 2 years ago. After putting the phone in recovery mode (holding both like a regular restart then letting go of power but continued to hold home button) it popped up on her screen and asked to update or restore. Because error 53 (detects any mods to the physical iPhone) I restored it. The restoration will take about 30mins. Well it did for me, I'm not sure if this is the best way to answer but it worked for me. Client retained all her contacts but lost all pics and messages. But phone wasn't bricked by error 53. Hope this helps.
Yeah, error 53 wont come up again. Louise, what error do you get?
댓글 달기
The iTunes can help you get iPhone out recovery mode,but this way may cause data losing.I recommend you a iOS System Recovery tool to get iPhone out of recovery mode when iOS 10 updatewithout data loss.
If you want to get out of recovery mode with iTunes,I recommend you should make sure you have backup your iPhone to computer,and install the latest version of iTunes on your computer.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
If you own an iPhone and one day it stuck in recovery mode, you can use the Tenorshare ReiBoot to fix it. It is a professional free tool to help you enter or exit recovery mode of iOS devices, including iPhone, iPad or iPod. So as the best iPhone recovery mode software for Windows and Mac platform, you can use it to fix your iPhone. https://www.youtube.com/watch?v=w9l2fIux...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
When iPhone stuck in recovery mode, you can enter dfu mode. Besides, if you need to recover some important data when your iPhone stuck in recovery mode: iphone stuck in recovery mode
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Get in the DFU mode and try to recover.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
To get out of recovery mode, make sure your USB cable is connected to both the laptop running iTunes and your device.You may need to hold the home button while connecting your USB cable as above. Now hold the home and sleep/wake buttons together until you see the Apple logo appear.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Joyoshare UltFix iOS System Recovery software can get your iPhone out of recovery mode with one click for free.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Todd June 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 5
전체 시간: 8,338
