주요 콘텐츠로 건너뛰기
2011년 10월 24일 출시 / 2.2, 2.4, 또는 2.5 GHz 쿼드-코어 Intel Core i7 프로세서
405 질문 전체 보기
질문 마감됨
spill tea on MacBook Pro but still working!
hi,
I have spill hot tea (with sugar) on my macbook pro. I turned it immediately and wait 72 hours. It turns back on and operating normally (?) Except F1, ... F9. But I can not turn it off, at this time it freezes.
I have read that could clean it with alcohol 90°C or demineralized water.
Is it correct ? If not what should I do to avoid rust?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Assuming you meant you turned it off immediately and waited 72hours. Good on you for doing so. However, I would not have turned it back on until I had cleaned the boards. I have fixed my nieces and nephews MacBook Pro since they are kids and spilt KoolAid on it. I would not worry about the rust issue too much since it is mostly aluminium (Aluminum does not Rust). To get it to turn off, I would hold down the power button until it goes off and not use it until you clean it with either suggestion. I personally use rubbing alcohol and it takes patience to ensure you have gotten it all.
Here is a guide on how to do this (although it says water damage the concept is the same) and should get you back up and running smoothly.
Electronics Water Damage (iFixit Guide)
Another quick sidenote: If you have a hairdryer this can be helpful in making sure everything is dry before reassembling. DO NOT USE HIGH HEAT SETTING as this may cause further damage, Low is fine at 6-8 inches from the components (your not trying to melt them, be cautious).
Best of Luck!
Hank
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 365
