주요 콘텐츠로 건너뛰기
The Dell Inspiron 13-7352 was first introduced in August 2014. It is a 7000 series laptop.
screen very dim after windows 10 update
laptop was working great up until windows 10 update.......screen very dim......need to point light to screen to see anything
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
선택된 해법
Hi,
Have you tried installing the latest Win10 video driver for your laptop. Maybe try 'safe mode' to see if the screen is more visible to allow you to update driver or try an external monitor and see if it allows you to see to update.
Here is a link.
http://www.dell.com/support/home/us/en/0...
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Sounds like the physical LCD has gone bad or the dimmer has been turned down all the way. I'm leaning more towards the LCD but check your screen brightness settings first. If your brightness settings are turned up all of the way and the issue is still there then it is the physical LCD. If it is the physical LCD then Windows 10 didn't cause the problem, that was just coincidence.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
tony 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 11
전체 시간: 1,424
