주요 콘텐츠로 건너뛰기
2세대 iPhone. Model A1241 / 8 또는 16GB 용량 / 검정 또는 흰색 플라스틱 뒷면. 첫 번째 iPhone보다 수리는 더 간단하며 스크루드라이버, 비집는 도구 그리고 흡입 도구가 필요합니다.
1158 질문 전체 보기
Touch function does not work on the bottom of the screen, why?
I have replaced the part and the installation proved to be easier than I though, however once I turned the phone back on, the touch function does not work at the bottom of the screen, I cannot hit the space bar and the lower letters...nothing...what do I do?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 9
댓글 달기
답변 4개
가장 유용한 답변
If the part that you just replaced is the digitizer panel
that means you might have faulty digitizer panel.
But before jumping to conclusions,i would open the phone again,
and i would disconect the cables #1 #2 and #3,and i would take out the lcd+digitizer panel assembly and set it aside.
Then i would check with a magnifier mirror,the contacts on the flat cable
#1 which is the one responsible for the digitizer panel and then i would take one of those aerosol spray cans,used for cleaning of computer keyboards and i would blow a few jets of air in the conector where the flat cable #1 goes in.That's the special one that you have to lift a small
piece of him to be able to put the cable in and then you have to slide it back down to secure the cable in place.
It might be a speck of dust or something small inside there that doesn't allow a good contact and then you don't have the bottom of the screen working,like you do now. Good luck.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
I believe you have a faulty piece of hardware. Maybe it was messed up during transit, or maybe you just bought a faulty one.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I had this same problem. Multiple restores, cleaned and reseated contacts, to no avail. I decided to try downgrading to 3.1.3, and after downloading an ipsw, trying to restore with it and getting an error, I restored to 4.2.1 without issue, bottom working perfectly. I'm not offering this as a tutorial as I'm mainly an Android guy, but it definitely worked for me.
Cheers,
tabormeister
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I have a nexus 7 and when I type it jumps to the next letter
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
stepharbour 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 13
전체 시간: 28,245
