주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
I cracked my phone screen but still on and its blacked out?
cracked it on Sunday and I was hopping to get it fix around this week and I was listening to music going to lunch and the screen just shut down. Once I was in class my phone ringed but couldn't answer because of the screen can I get the screen fix or will I have to replace the phone?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 21
댓글 6개
I have the same problem currently. Will they replace my phone though? Or will they call it busted, if this can be solved let me know. Please. I have an IPhone 5S.
Can i have it then
if your screen is cracked and its not turning on or its black you can fix your screen its the screen back wire in the back of the phone that ripped that made your phone turn all black all u have to do is get a new screen put it on your phone and boom it turns on and the screen not black anymore. hope this help u!
Or! you can plus in your headset, and use the toggle buttons to answer calls... just can't text anybody.
i have the same problem, like before my phone is still on and i get notifications but the screen is black and i dont know how to fix it
댓글 1개 더보기
댓글 달기
답변 4개
선택된 답변
I think you need a new lcd :)
해당 답변은 도움이 되었습니까?
점수 4
댓글 달기
Try to do a hard reset on your phone.
Hold the power and home button for around 7 to 10 seconds. This should reboot the device. Let go when you see the Apple logo. Your phone should be fine now.
If not, let me know and Ill suggest other steps.
해당 답변은 도움이 되었습니까?
점수 3
댓글 7개:
will it restart the phone
It will restart the phone.
More than likely the lcd is bad and needs to be replaced. I have seen a hard reset fix this issue sometimes.
my screen come on but it send me message but i cant see them and than the screen go back to black out
I tried this and it showed something else like a gray thing and gray lines and i can barely see the apple than it goes back to black and it did this over and over again
댓글 2개 더보기
댓글 달기
Yup, you'll have to replace a new LCD, it costs about $100 to get a replacement online. Here are the part and tutorial guide 's links you may need:
Part: http://www.etradesupply.com/apple-iphone...
Tutorial: iPhone 6 LCD 및 디지타이저 교체
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
not yet , You can used it as usual
But if you want to replace a new original screen,Here are the part may you need
iPhone 6 screen:http://www.hcqs.cc/iphone-6-lcd/iphone-6...
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
I cracked my screen and it doesn’t show anything but Ik it still turns on Bc my home button clicks (I have a 7 plus) another thing is when it cracked I asked someone to call me to see if I can hear it and I couldn’t
댓글 달기
귀하의 답변을 추가하세요
jesusa mejia 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 5
7일 전: 23
30일 전: 143
전체 시간: 78,012
