주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
The Fujifilm X30 is a point and shoot camera with a 3.0 inch LCD screen.
Why is the LCD screen not working?
When I turned the camera on, the screen appeared black. I could tell the camera was working and taking pictures because I could hear the shutter sound and it could still zoom in and out. I've tried turning the camera on and off multiple times, but it still will not turn on. My daughter's 1st birthday is coming up and I really need the camera to take pictures. Please help.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 7
댓글 3개
The LCD screen on my Fuji S700 quit working, too. Finally, I did a "reset" and the screen came back on.
How to reset please?
Mine too on my X-A5 fujifilm camera :(
댓글 달기
답변 3개
선택된 해법
Hi Jay,
First, you might want to check that your lens cap is off. If that wasn't it, then you should clean the lens. You can also refer to the the Fujifilm X30 battery replacement guide. I hope this was helpful!
이 답변이 도움이 되었나요?
점수 4
댓글 달기
Provided it is not that EVF is selected, or lens cover is on, it could be:
  1. screen broken
  2. screen connector malfunction
In the first case it could be caused by a drop or similar. You should see evidences of broken screen on glass. In this case it should be replaced.
You should disassemble the LCD.
Follow disassembly guide but just step 18, no need to teardown the whole camera.
On the second case it could be caused by humidity or water, or even a drop that has moved flex cable from its connector.
You should disassemble the LCD and inspect it.
Follow disassembly guide but just step 18, no need to teardown the whole camera in the first place.
Remove LCD and adhesive tape. Clean every connector and component with isopropyl alcohol and a toothbrush. I managed to revive my LCD that was only showing white light and some stripes.
With LCD in place, test voltage on slim power connector/flex cable. On my camera it registers some 15.30V
If voltage is ok and LCD is not lighting up (some white light) it should be replaced. If LCD is lighting up but showing ghost image or stripes, video connector should be cleaned.
If no voltage is registered, you'll have to disassemble the back of the camera and inspect flex cable and connector from mainboard. And clean and replace if needed.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
There is a small button on top of the viewfinder, on the right side that written "View Mode". If it pressed accidentaly it will make the LCD screen blank. I've experienced this twice and and made me worry for quit awhile. Nothing is broken, thankfully.
이 답변이 도움이 되었나요?
점수 2
댓글 4개:
Thank you Fajar Sutrisno! I also was worried when my LCD screen was black. I turns out that I accidentally pressed the "View mode" on the right.
Simplest solutions are always the best. Solved my problem too!
My LCD stopped working. I figured it might be the ribbon cable, so I bought one and asked someone who repairs electronics to replace it for me. They returned the camera saying they had installed the new cable but didn't have the tool to connect it. In other words, the cable is in there, but I need to connect it. Is there a solution I can handle myself?
댓글 달기
답변을 추가하세요
Jay Sterner 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 40
지난 30일: 220
전체 시간: 41,247
