주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
Consistent lower GSM signal
I bought a second hand iPhone 5S and i have one problem with it;
My phone barely gets 5 bars of 2G, whereas every other device around me has 5, i only have 4. But it doesn't stop there. When i compared the signal strength between two 5s' using the same carrier, i can see a consistent "one bar less" on my phone and they are both using a 2G/3G network. I tried putting my sim in my friends phone and he receives 4 bars on it while i only get 3, so it's not the simcard. It's like my antenna is way more sensitive than his.
Could it be the gsm antenna? The phone probably fell on the edge where the GSM antenna is, considering that edge has some damage.
What else could it be? I'd like to know what's wrong before actually visiting a service center.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
Umm........................ bump?
댓글 달기
답변 1개
선택된 답변
It could likely be your antennae. Have you tried resetting your cellar settings?
iPhone 5s Lightning Connector Replacement
iPhone 5s Lightning Connector and Headphone Jack
iPhone 5s Lightning Connector and Headphone Jack 이미지
상품
$24.99
해당 답변은 도움이 되었습니까?
점수 2
댓글 3개:
I have, it didn't have any effect on the signal strength
You tried both of those things?
Oh no no I only did the reset, thanks for the tip I'm gonna visit the service soon and let you know how it went
댓글 달기
귀하의 답변을 추가하세요
Tomi 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 2
전체 시간: 555
