Why after replacing a bulb with the housing, a blinking yellow light
yellow blinking light came on after replacing lamp.
좋은 질문 입니까?
좋은 질문 입니까?
Hi,
Is the lamp door securely shut?
There is a safety switch that operates if it is not closed properly. Also check that the door is not bent or warped from the heat.
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds. The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Hopefully this is of some help.
해당 답변은 도움이 되었습니까?
TX that is helpful …. I appreciate you
The lamp door cover screw had come loose just enough to produce the blinking yellow light & subsequent turning off of the tv. I removed the screw & cover, cleaned & repositioned the cover & tightened the screw. Blinking yellow light is gone! Solid green light only now. Thank you!
해당 답변은 도움이 되었습니까?
24 시간 전: 3
7일 전: 10
30일 전: 25
전체 시간: 7,931
