주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
듀얼 카메라를 탑재한 8인치 정전식 듀얼 코어 Zeki 태블릿입니다. 이 기기의 모델 번호는 TBQG884B입니다.
Device won't boot past "Android logo" splash screen
Presently, device will boot past the "Zeki" screen but will hang on the "Android" screen. We've let it sit for more than 60 minutes.
Attempted to do a factory reset.
Physical and online manuals do not address how to do this. Listed technical support has been unhelpful. Attempted at least twelve separate, recommended ways of doing a factory reset using the physical buttons (Pressing multiple combinations of the power button, vol + / vol - / both, and the reset button for varying lengths of time at different times during the reboot process). However, I'm certain I haven't tried every combination of buttons, press durations, and timings.
As a last-ditch effort I'm letting the battery run out in an attempt to make it forget everything, but I don't if that will accomplish anything (or how long that will take--days? weeks?).
Any advice on how to achieve a factory reset for this device, or otherwise restore functionality?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 8
댓글 달기
답변 2개
Try holding down the power button and the volume down button for five seconds and then releasing them. This should bring you to the fastboot menu where you can perform a factory reset, I would try this again.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
eso ya lo hice y nada. que hago entonces?
의 공유
Es posible que haya alguna manera corrompido los archivos de Android, si ese es el caso, no hay nada que pueda hacer por ti. (Estoy usando Google Translate, lo siento por la redacción raro.)
의 공유
댓글 달기
test combo: vol_+ & pwr_btn
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Chris Rutledge 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 26
전체 시간: 2,876
