주요 콘텐츠로 건너뛰기
MacBook Pro 13" Retina Display, 모델 A1502의 2015년 3월 업데이트는 5세대 Intel Core i5 및 i7 프로세서를 포함하며 Force Touch 트랙 패드를 소개합니다.
Where are the power pads to short it on?
I’m looking for the pads to touch to short it on to check to see if my keyboard is broken.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
David Molinari you can do this by either shortening pin 5 of the keyboard connector briefly to ground. You can also use the debug pads as pointed out.
이 답변이 도움이 되었나요?
점수 9
댓글 8개:
Thank you very Much oldturkey03!
Hey! When I short the two pads it turns on but the fan goes on at full speed and doesn't stop. Where is keyboard connector 5 by the way? Thanks in advanced!
Hi, thank you so much!!!! I've been searching these power-on pads for so long...
I "only" have to replace the keyboard now.
Must i disconnect the keyboard in order to power up with power pads ?
francoisvdc no you do not.
댓글 3개 더보기
댓글 달기
답변을 추가하세요
David Molinari 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 47
전체 시간: 23,658
