주요 콘텐츠로 건너뛰기
A 14.1 MP camera released in 2012. The Nikon Coolpix L310 support and repair information.
17 질문 전체 보기
Broken SD card pieces are stuck in the card slot.
I took out the SD card out of the slot and found it had a few pieces of plastic missing. The plastic pieces are stuck in the card slot. How do I get them out? I am not able to insert a new card into it.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 5개
선택된 답변
Make sure power is off - take out battery!
Fine, needle long nose pliers with a good light and a magnifying glass.
Slowly, slowly!
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Take the camera to a repair shop, don't try to pry the pieces out, you will damage the sd card reader.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
First of all you have to have good soft solder skills with thin. Find all screws. Specially the ones of the microphone. You have to dissasemble the shutter board from the main board. You will have to remove the solders. Are 12 or so. The main lens flex connector is a PITA. Takes around 1 to 2 hours to fix it. The lock of the sd card switch is bent all the time. Reshape it to the original position very careful. Is tiny.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
You can try to clean SD card by blowing air into it or with some folded paper. This may help to sort out your problem.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Having the same problem with my Lumix GH5S. Unfortunately Panasonic has told me it will cost $250 to replace the slot (stuck in slot 2). I use the camera primarily for films so having 2 slots is one of the reasons I bought the camera. After taking it to the service center ( I live in Korea ), they had it for one week . I was told that the card is so jammed into the corner of the slot that the only option is to replace the part, which will unfortunately take up to a month to arrive in Seoul. However, if I'm able to fix it then I they'll just use the part for someone else. After getting the camera back and magnifying the inside with my phone camera, I can definitely see the chunk in the corner, and it looks literally packed in. The best part of the story is that it appears to be my friends SD card. Happy smiles all around.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I’m having exactly the same situation with my GH5S here at the moment. Need to shoot tomorrow. Pretty lucky
댓글 달기
귀하의 답변을 추가하세요
Rom 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 29
전체 시간: 3,946
