주요 콘텐츠로 건너뛰기
The third generation of the Apple iPad, released on March 16, 2012. Full 4G and Wi-Fi model repair guides. Repairs require heat and careful prying. Model numbers: A1416, A1430, and A1403.
Glass keeps popping up on side of home button.
After I complete a iPad 3 repair the glass never stays where it's suppose to stay. In other words it begins to separate from frame.
Here's what I do before I place adhesive down.
Remove bezel clean all old glue from under bezel. Remove all old digitizer glue from around frame. Scrapping with a plastic tool then I use alcohol pads to remove any remaining glue from old tape. I place new tape in bezel slot and peel the back off then place new bezel on, pressing it into place with a tool. Then I peel off back of the already installed tape on new digitizer, this pre installed tape on underside of digitizer glass is a great idea by the way. I push glass into place pressing all along the outer edge of iPad. I then heat up edge to get glue nice and sticky and finally secure the edges with small wood clamps to hold it in place. The next day, about 24 hours later I remove the clamps. By the next day or so the glass begins to seperate, usually around home button side. Any ideas on how to make a perfect seal?
Thank you
Dave
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
Sounds like there is pressure which is pushing up on the digitizer which can happen from the digitizer cable not being properly positioned or folded wrong . Could also just be cheap adhesive strips .
Easiest way to solve this would be to use a liquid adhesive in the troublesome areas. Look for E7000 Glue on ebay . Once dry it acts like a strong and flexible adhesive that can be removed with heat in the future.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Dwinterone 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 15
전체 시간: 119
