How do I wire a tachometer
how do i wire a tachometer on a 1993 jeep grand cherokee
좋은 질문 입니까?
jimmiller1940, as a general answer since we do not know which tach you have, most aftermarket tachometers only have 3 or 4 wires that need to be connected. Usually a green wire for the tach, red for power, black for ground, and white or yellow for the back light. The power wire that gets connected to a 12 volt ignition source, the tach signal wire that connects to the coil or the designated signal wire in your cars wiring diagram.
해당 답변은 도움이 되었습니까?
24 시간 전: 2
7일 전: 4
30일 전: 9
전체 시간: 949
댓글 1개
what make and model is your Tach? Post some images of the connectors with your question. Use this guide 기존 질문에 이미지 추가하기 for that
oldturkey03 의
