주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
Dropped and is completely dead
So i was using my iPhone 6 when cleaning out the fan of my Macbook Pro as a light source. I was sitting in my bed and it slipped of the side of the bed. It dropped and the flashlight and screen immediately switched off. I opened up the phone to check if it was just the screen that had disconnected, i also checked the battery. My phone does not respond to home+power, the mute switch, turning on or charging. I also tried to get a software to detect the phone when connected but even that didnt pick it up. I have no idea what to do. Does anyone know what to do?
NOTE: Phone had a broken screen previously
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
Hello.
Sorry for the trouble you are experiencing. If you are not getting any power even when plugged in, I would recommend that you remove the battery cable cover and check the connection.
Steps 18 and 19 should be consulted from the manual below.
It is possible that even through the connector seems to be sitting properly, it may have come loose. Unseat the connector and then inspect it for any damage. Reseat the connector carefully and then power the device on.
iPhone 6 배터리 교체하기
I would love to know how it turned out for you. Please don't forget to reply back.
Regards,
Michael
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
marcogronn 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 4
전체 시간: 1,987
