My Vacuum Cleaner Turns Off After Few Minutes. What Should I Do?
Hey guys,
Ever since I vacuumed my red Persian carpet, last week, the vaccum cleaner started working poorly and after a few days, it started turning off after just a few minutes of use.
I opened the panel and replaced the bag and cleaned all the filters. Unfortunately, with no success at all. The machine appeared to work normal the first couple of times I tested it, but then it completely stopped and never turned on again. I read on the forums that I should unplug it and turn it off for an hour or two and then try it out in a different socket. Again, it didn't work.
Has my vaccum cleaner completely gone? Should I be worries or is there a way to fix it?
I'm not an expert in repair nor do I understand electronics, but wanted some opinion on what could the problem possibly be so I can prepare myself for any additional repair costs or just go to the store and by a new one.
Make sure you include references or pics, if possible, so I can get familiar with the issue you'd be referring to.
Take care and thank you all for the help!
A. Polter
좋은 질문 입니까?
12 Comments
What's the make and model number?
mayer 의
Electrolux EL1200 upright rechargeable cordless shutting off after a couple of second
Laurna Calabrese 의
Mine just shut off and won't come back on. Black and decker lite series
Natasha Teets 의
Hi @tash88 ,
Were you using it for a while before it shut off or only a minute or so?
If using it for a while, is it/was it feeling hot to the touch around the motor area?
If it is allow it to cool down before trying it again.
Most wall powered vacuum cleaners have an internal safety switch that turns off the power to the motor when it gets too hot due to airflow restriction, to protect the motor (and to prevent any potential fires)
Have you checked that the filter is clean and not clogged up? Is the dust canister also reasonably empty or at least not full to overflowing ;-).
jayeff 의
My power tool won't come on. I've put in a new bag and the machine comes on but not the power tool. What else can I do?
kendallcole 의
7에 댓글 더 나타내기
