주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Fujifilm에서 출시한 이 즉석 카메라 모델은 이전 버전보다 더 얇고 가벼워졌습니다. Mini 8은 권장 조리개 값을 알려주어 촬영을 도와줍니다. 또한 하이키(High-Key) 플래시 모드가 있어 부드러운 인물 사진을 촬영하여 멋진 결과물을 얻을 수 있습니다.
Camera won't switch to different lighting settings
I brought my instax mini eight out for the first time to take a couple pictures on a hike, and when I went to adjust the lighting from indoor to cloudy, it didn't change. The orange light switched between all of the settings without me turning the dial, and eventually became stuck on the indoor setting. Can the camera be fixed?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 7
댓글 5개
umm what if the lighting setting/the adjustment for the lights does not flash
의
My film wont came out and the censor light wont turn down even when i shut the camera down, how can i fixed it ? :(
의
my light doesnt change to any of the icons it just stays on "home" icon, I JUST GOT IT OUT OF THE BOX
의
My problem is that, all of the icons are all lighted? How can I fix this? Please I badly need help. Thank you
의
I had the same problem! It may be just a mechanical problem but if you look closely at the lense, you will see that it still opens and closes with each dial turned. The orange light is just showing what its on but with that broken, the whole thing still works. The lense with the biggest opening brings the most sunlight and the smallest opening is the darkest setting. Hope this helped!
의
댓글 달기
답변 8개
선택된 해법
I don't think the camera is broken to begin with.
The orange light next to the exposure dial suggests the correct setting of the dial, it isn't supposed to change when you turn the dial. You just have to turn the dial so it matches the light.
The correct procedure is to point the camera in the direction of the subject, then turn the dial to match the light. Also, on the front of the camera next to the flash window there are two small round holes, be careful not to cover these with your fingers when you hold the camera: these are the light sensors, and they cannot work correctly when they're covered.
이 답변이 도움이 되었나요?
점수 18
댓글 6개:
Its causing my photo quality to be bad or faded because its so sunny where I am at.
의
Thx so much It really helps me bc I thought mine was broken this lets me know that some people are also having this problem that can be solved
의
What if the light on the dial won't turn on
의
thank you so much, It never did that before so I thought it was broken.
의
I tried it in a really dark place and then outside when it was sunny, and the light dial still the same. This causes my photos to go dark, is annoying.
의
댓글 1개 더보기
댓글 달기
thank u!!! this really helped
이 답변이 도움이 되었나요?
점수 2
댓글 달기
thank you so much!!!!!!!!!! I thought my camera wass broken bc it wouldn't switch light positions, but now i know it is fine.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
but i had this since last christmas, it was like thaat as soon as i opened it, and even in the sun it does not change dials or settings...
의
댓글 달기
Thank you so much!!!! This really helped
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Omg this makes so much more sense thank you so much.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I put my new film in the instax mini 9 but the S is not changing to 10 and it is not taking pictures.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Wow! Thanks, it makes TOTAL sense. I was already thinking the camera was broken!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Oh wow I was having the same problem with my instax mini 9 and also though it was broken Thanks.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Kelly Giordano 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 7
지난 7일: 30
지난 30일: 111
전체 시간: 142,053
