주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Inspiron 15-3521은 15.6형 디스플레이와 선택 사양인 터치 스크린 기능을 갖추고 있습니다. 또한 무광 마감 처리와 숫자 패드가 포함된 키보드가 특징인 노트북입니다.
No Boot Device Found
Just replaced my hard drive with a new one from ifixit, when running diagnostics it now shows no errors when previously it said there was a problem with the hard drive. On boot up it states: No Boot Device Found. Press any key to reboot machine
On the boot menu after pressing F2, I only have the following options:
LEGACY BOOT: (which is gray)
UEFI BOOT:
When selecting UEFI BOOT:
UEFI Onboard LAN IPv4
UEFI Onboard LAN IPv6
It doesn't seem to matter which order they are in
After reading all other forums, I have not found a solution to this.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
선택된 해법
did you format your drive re-install your Operating system on the new hard drive? When you boot to BIOS check if the hard drive is getting detected there or not. Here are the steps:
Restart the system and immediately start tapping the 'F2' key to enter the 'BIOS'.
Please check what is written next to 'Fixed HDD'.
Double check your installation and your drives compatibility
이 답변이 도움이 되었나요?
점수 2
댓글 달기
So if I enter f2 and enter bio what next, because my dell is still on fixed HDD ( not detected) . What should I do next?
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
tucrkilerita what is your computers make and model? This is a new hard drive?
의 공유
댓글 달기
답변을 추가하세요
Karen Chandler 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 23
전체 시간: 15,399
