주요 콘텐츠로 건너뛰기
The OontZ Angle 3 is a high quality, lightweight speaker made by Cambridge SoundWorks.
Why doesn’t the speaker connect to my phone?
I keep trying to connect my phone to the speaker, but regardless of what I do there is no connection and no music is playing. What’s the best way to fix this?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 5개
선택된 해법
If your speakers doesn’t connect to your phone, first, make sure the Oontz angle 3 is on and in pairing mode, the blue light should be flashing. Make sure the Oontz is not connected to another device. Also, you will want to check and make sure your phone’s Bluetooth is on.
If the both devices’ Bluetooth are on and it still not connecting, the problem might be that there are objects between the phone and the Oontz or the phone and/or the Oontz and phone are too far to maintain a connection. Clear the obstructions and keep the speaker and the phone near each other to maintain a strong connection. If the connection issues remain or more problems arise, refer to the troubleshooting page.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
The speakers used to come on and let me know who was calling let me know who was on messenger that I had a message it stopped
댓글 달기
Problem is I have to do this every day. It is almost as if the bluetooth address changes every day. so I unpair and repair every time I use my Oontz Angle
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Me too how to solve this
댓글 달기
I tried all that and no connection between iPhone and Oontz angle. So on my iPhone I clicked on Bluetooth in Settings, then i tapped the i ℹ️ to the right of the words Oontz Angle, and then I tapped “Forget this device” — removing Oontz from the list of Bluetooth devices on my phone. Then, making sure Oontz speaker was still turned on, with a blue light, I let my iPhone find new Bluetooth devices. When it found Oontz, I clicked on Oontz and finally the connection was made. Music!!
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
That worked, but I still need to "forget device" and re-pair every time I turn on the Angle 3. Is there a way that I can turn on the speaker and my phone and have it automatically connect without having to go through the "forget device"...??
Also, I've done a factory reset a few times as well. No luck.
댓글 달기
Me too! iPhone 8 won’t work. My wife’s 7 does, and my phone connects to other devices just fine. Tried forgetting device but no luck.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Mine was connected to my other device and I had to turn the other devices bluetooth off and the speaker responded to my original device and the speaker was fine.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Mason Hollander 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 20
지난 30일: 92
전체 시간: 24,859
