주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
I think I may have fried my headphone jack
I bought a powered subwoofer at a thrift store and I tried to plug my phone into it. The sound was all distorted so I unplugged it. Now whenever I plug headphones into my phone the sound is very distorted. There is also a slight burning smell coming from the headphone jack on my phone. Will replacing the lightning/headphone jack unit in my phone fix my issue, or is it possible that something on my logic board has fried?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 3개
Audio still sounds fine when played through the speaker, only the headphone jack is affected.
Have you tried new headphones after you replaced your dock connector? Just in case.. If yes then like you said something is damaged on the logic board.
I have tried different headphones and still have the same issue.
댓글 달기
답변 1개
가장 유용한 답변
Doesn't hurt to try as the phone part is cheap. It will most likely fix it.
Link on where to buy the phone part:
iPhone 5s Lightning Connector and Headphone Jack
Repair guide for lightning connector:
iPhone 5s Lightning Connector Replacement
iPhone 5s Lightning Connector and Headphone Jack 이미지
상품
$24.99
해당 답변은 도움이 되었습니까?
점수 3
댓글 3개:
Good answers include links to the parts and guides.
Thanks, I may give it a go and see how it turns out. It doesn't look too difficult to replace.
unfortunately, replacing the jack did not work. The sound is still distorted.
댓글 달기
귀하의 답변을 추가하세요
Kris 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 5
전체 시간: 1,620
