주요 콘텐츠로 건너뛰기
Announced October 22nd and released November 12th, 2013. The iPad mini 2, also known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
426 질문 전체 보기
Do I need to replace my fpc connector?
I'm in the process of replacing my ipad's digitizer and when I was testing the new digitizer, the new screen wouldn't track movement. The home button works fine but that's about it I'm not sure if it's a defective screen or what. I looked online a little and saw some people talk about needing to replace the fpc connector, so I took a look at it but I'm not sure if that's the problem or not.
http://postimg.org/image/5x2hjd6qp/
Should I replace the fpc connector or should I get a new digitizer?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
RuiXu Tsai your image is not very clear but the actual connector looks okay. Now we cannot see the components on the board which may be an issue. Since the replacement of the connector will require some pretty good soldering skills and some decent tools etc. I'd suggest that you start off with the replacement of the digitizer. Start with the easier things first and work your way into the complicated area.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
귀하의 답변을 추가하세요
RuiXu Tsai 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 160
