주요 콘텐츠로 건너뛰기
D1760-2 DECT 6.0 Cordless Home phone with caller ID.
190 질문 전체 보기
I bought a new battery, but why doesn't my phone work?
My phone will not work. I bought a new battery, and the screen lights up, the red light is on, but I cannot make or receive calls. The volume, answering will work, but won't turn off until I press the buttons.
The screen message is Handset #1New CID:50
Please advise. Thank you.
Perhaps these numbers will help to identify my phone. I've had it for some time, but don't want to replace it.
M/ND1680
IC-513C-UN244
REN.0.0 311E0811
BQ 80685754
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Hi,
The red light indicates that the battery is charging. What is the battery display in the phone showing? Have you fully charged the battery?
By replacing the battery you may have removed the 'registration' between the base and the handset.
Try resetting the handset to clear the registration information from the base and the handset.
Press & hold END and # at the same time until you see the System Reset menu.
If you still have the base the handset is registered to, select Deregister HS, then select the handset you want to reset. To confirm, select Yes. The handset displays Handset not registered
If you see a “not registered” message on a handset, you must register it to a base before using it.
Place the handset in the base; the display should say Handset Registering.
Wait until the display says Registration Complete (about 30 seconds), then pick up the handset
and press TALK/FLASH. If you don’t hear a dial tone or the display says Registration Failed, charge the battery completely, then try again.
By the way your phone is probably a Uniden Dect 1680.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Hi
This process doesn’t work for me. I still get registration failed. What should I do?
@benhunter87050
Did you try registering the phone by having the phone next to the base station?
댓글 달기
귀하의 답변을 추가하세요
Mary Lein 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 36
전체 시간: 4,338
