주요 콘텐츠로 건너뛰기
Turns off, or fails to activate
This is a cordless Phone, which is fully charged, however, a few seconds after picking
it up (from its Stand) it switches itself off; Now, Both of these Handsets act in a
similar manner.
I have tried pressing 1,4,7 & Red key, service signs appears, then Shuts off.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 16개
Hi
I have the same problem, shut down during a call or during the dial process with a C530A duo.
Both handsets worked well for 3,5 years, now both give the problem.
I put in new batteries in both handsets, seemed to work ok, but now I have the same problems.
The battery indicator sometimes shows red, when testing the batteries out of the handset it shows they are full.
After putting the batteries back in the handset works for some time.
Any new ideas?
I have similar probs with gigaset C300. Can anyone tell me if you should leave handset in cradle in between calls or wait until it runs down before re-charging? I suspect if the batteries are constantly on charge it wears them out faster anyway
My conclusion after almost a year of testing on 4 Gigaset phones: not all rechargeable batteries are the same!! realy!! So only use the batteries that are certified in the Gigaset list or just order at Gigaset, no problems anymore!
My 3 phones are flashing 'no base' what does this mean
@Sandra Light
Does that base station have power connected to it?
Does it indicate that it is on?
댓글 11개 더보기
댓글 달기
답변 6개
가장 유용한 답변
Same things happend to my pair of Gigaset AS28H and I suspect it is some kind of planned obsolescence feature planted into the hardware. It seems like when the battery voltage drops to little less than 2.4v it shuts off. Given that the regular rechargeable batteries are rated at 1.2v this is pretty close.
해당 답변은 도움이 되었습니까?
점수 4
댓글 3개:
Had the same experience, ordered Gigaset certified reloadable batteries at Gigaset support. They work fine for 3 weeks now. The Duracell rechargeable batteries I used before were not certified for use in the handset.. At a low tension (1,20v per battery) they do not deliver sufficient current for the handset and it seems the low battery circuit detect this low current and shuts down the unit. The certified batteries do deliver still sufficient current at low voltage. But I still have to see if my conclusions stay correct after several months of usage
No, it is not "planned obsolescence" but a consequence of placing already charged batteries into the telephone, which then overcharges them. Read:
https://service.gigaset.com/en/support/s...
The telephone assumes that the batteries are UNCHARGED when first inserted, and proceeds to charge them at maximum voltage for 8.5 hours before switching to trickle (low) charging. When the telephone is removed from the charger base, it measures the discharge current, to try to learn how long to charge when the telephone is connected again.
The problem occurs when fully charged batteries are inserted. The telephone tries to charge them at maximum voltage, which ultimately degrades/destroys them. Unfortunately new NiMH batteries are usually pre-charged, so are usually damaged by overcharging.
Gigaset uses this charging method because it is difficult to measure the real charge level of NiMH batteries.
Hibou
So if new charged batteries are used, they should be allowed to fully discharge before the phone is placed on its charger base. Then after charging, without removing the batteries, the phone should be allowed to fully discharge before it is again placed on its charger. After that, the phone can be left on the charger because it has learned the capacity of the battery, and only trickle charges it.
These documents are difficult to find on the Gigaset site, and even the manual for my old S79H model is hidden and can only be found with Google.
https://gse.gigaset.com/fileadmin/legacy...
Hibou
댓글 달기
I have exactly the same problems now with al gigasets S79H sets. It started with one but now all three have the same problem. I noticed that with new rechargeable batteries, they function OK, till after some time the problem repeats itself. I also have a different gigaset S68H and that one functions well but it has a different charging holder with similar adapter , thus I never tried to put the S79H sets in that charger holder because they do not fit. Now I noticed that all S79H chargers deliver without load a very high voltage and also the batteries are overcharged to a rather large voltage ( for both in series 2,95 volt which is excessive). Apparently the gigaset unit then decides to switch itself off to protect the telephone. My conclusion is that all 79H charging adapters have gone faulty after so many years and deliver a much too high charging voltage which causes the units to switch off to protect themselves. When new batteries are installed or batteries charged with an external general purpose charger the voltage per battery is much lower and the gigasets function normal till they are put in the chargers again. The adapter of that unit S68H which works OK , delivers indeed a much lower voltage without load . 5.73 volt versus 7.5 to 8 volts of the S79H adapters while the adapters are interchangeable . I am pretty sure that that is the problem because I have taken the S68H adapter out of the S68H charge holder and have put it in the S79H charger holder and now charging the S79H does not cause a switch off.
I have already ordered three new adapters.
Updaten (02-03-20)
In retrospect the problem with the non-lasting batteries in my gigaset dect sets, is that I used batteries which were not of the right quality. I am now using high quality eneloop batteries and I have no problems anymore. And strange enough also the Ikea laddo batteries also seem to work. They are apparently made by the same Japanese factory.
Updaten (13-06-20)
Dect batteries
Dect telephones like the gigaset telephones require low self discharge NiMH AAA batteries, because they do not seem to wear out by the continuously charge when they are placed in the charger like the cheaper brands.
Since I use these low self discharge batteries I do not have the problems discussed here. ( Showing battery empty sign and switching off after a short while)
Eneloop batteries ( original made by Sanyo but now Panasonic) are made in Japan.
Several other makes are made by the same the factory ( like the Ikea brand Ladda and also Fujitsu) and are obtainable for a lower price.  Also the Amazonbasics batteries exhibit a very low self discharge (after 24 month still 80% charge). If you check the rechargeable Battery brands advised by Gigaset or other Dect telephone manufacturers one wil find that they all have low self discharge specifications.
Eneloop is a brand of 1.2-volt low self-discharge nickel–metal hydride (NiMH) rechargeable batteries and accessories developed by Sanyo (later acquired by Panasonic), introduced in 2005.
Eneloop cells lose their charge much more slowly than the 0.5–4% per day loss by older-technology NiMH batteries, retaining about 85% of their charge for a year after charging.This allows them to be sold precharged and ready for use, unlike older types.
Because they can replace a large number of alkaline batteries over their life cycle, they are marketed as being eco-friendly.
Sanyo was acquired by Panasonic in 2009. In exchange for the US FTC's approval of the takeover, Panasonic agreed to sell Sanyo's portable NiMH battery business to Fujitsu subsidiary FDK in order to preserve competition,and later did so.
Following this, Panasonic retained the "Eneloop" trademark, but continued to source the batteries themselves from the same former-Sanyo factories (now owned by FDK).
Following the acquisition of Sanyo by Panasonic, a fourth generation was introduced in April 2013. The number of charges per cell was increased from 1800 to 2100 cycles for both AA (BK-3MCC) and AAA (BK-4MCC) models. In some countries the batteries are branded as Panasonic.
The eneloop type quality batteries with the extremely low self discharge do not seem to wear out when continuously charged like other brands and retain their quality for a much longer time.
Of course there are more mostly Japanese brands which exhibit more or less the same low self discharge properties which are also suitable for dect telephones. Do not select the types with more than 900 mA capacity. The lower capacity ones last longer and can have more recharge cycles.
해당 답변은 도움이 되었습니까?
점수 3
댓글 6개:
What do you mean 'not of the right quality'?
Indeed the specification is for NiMH.
The only fault you can get that shortens their life is overcharging which is almost certainly, given the reports, is what the Giga handsets do.
High quality rechargeable batteries have a very low self discharge (LSD). If you leave them unused on the shelf , they will hardly loose their capacity after a year, while batteries of less quality will have lost their capacity almost entirely.
Select Eneloop AAA batteries made byPanasonic or Ikea Ladda batteries (exactly the same but cheaper) or the Amazonbasics batteries with low self discharge.
I bought eneloop batteries last April. I hardly use the phone - maybe three times a week. Rest of the time its on the charging cradle. Today took phone off cradle showing full charge and within 20secs had gone off. So Eneloop not the answer,
I have been using the Gigaset selected batteries for 10 months without any problem anymore.... but now I have the problem again after charging the phone in the master unit. Further testing revealed that the batteries in the master unit get extremely hot. Then after some time they start loosing the capacity, although in an external microcontrolled charger they are "fully charged". The handset in the slave charger units do not have the problem. I dit some further testing, including with new batteries and it seems that the master unit charger does destroy the new batteries. So if you have problems with batteries : lost capacity and hot in the cradle, it means the charger is not working correctly and even will destroy the batteries. My solution I use only the slave units for charging, no problems for 3 months anymore.
댓글 1개 더보기
댓글 달기
I am having very similar problems, with older phones which used to really consider as suspect. Not lasting and constant resetting
However I am now suspecting the battery chargers. I have a mix of the originally supplied batteries, eneloops as well others. They all fail in the phones after a few months of use. I also have a state of the art battery panasonic battery charger and have always been confused when I insert perfectly charged batteries into the phones which the phone then reports as half charged. I do not feel that is right.
After reading this article I had a closer look at three of my four Gigaset charged. All well over 3 years old.
• C39280 C710 measured 7.53v(no load) yet label on charger said 4v 6.68v with 100Ω load
• C39280 C710 measured 8.0v(no load) yet label on charger said 4v
• S2181 measured 7.50v(no load) yet label on charger said 4v
I would love to know what a newish 4v gigaset power supply reads.
Anybody out there able to state what voltage a new gigaset 4v charger outputs?
해당 답변은 도움이 되었습니까?
점수 2
댓글 4개:
Any charger with no load will give out more than the stated voltage,they will be simple chargers. Rechargeable batteries voltage should be aprox 1.25 volts not the 1.5 of non rechargeable types.
Thanks. But I suspect these are not simple chargers, NiMh do not like simple chargers. I have opened a support case with Gigaset complaining about my three chargers. They confirmed they should be 4V. As stated above I also measured the voltage with a 100Ω 50mA load and recently measured 6.8V. I believe the problem, in most of the above cases, to be overcharged batteries due to too high a charging voltage.
The voltage across the two batteries in the handset was 2.8V. Far too high. The handset turned off moments after being removed from the cradle.
@ Fergus McMenemie,
Do you have a practical conclusion. I.e. will the firm replace the holders? They never worked and I tried several batteries from Varta to Ikea Ladda. Sometimes worked for a rather short time, but suddenly not anymore.
Should we throw the holders in the garbage bin?
I don’t read any definitive solution here…
Thanks
Proper battery charging usually function as current source - they supply a constant current within a pre-defined voltage range. They should cut off once the target voltage was reached and then switch to trickle charge based on voltage drop.
댓글 달기
The new charger arrived courtesy of siemens support. Its voltage was effectively identical to my own three chargers. So my assumptions in the previous post are either totally wrong or this new changer is also duff. I cut one of the gigaset charging leads to allow use of two multi-meters and tested two phones. The charger measured 7.534v on no load, ie. nothing in the cradle. I got to work with two DVMs and started monitoring the current and voltage going to the cradle, in the end I also used a scope.
placing bigroom C430HX phone on cradle (batteries almost fully charged)
* initially 4.744v and 150mA when first placed
* then 7.480v and 2ma after a few min
placing int3 C430HX phone on cradle very flat- battery icon red and empty
* initially 5.381v and 183mA when first placed 11:14am
* 4.745v and 178mA at 12:15pm
* 4.681v and 180mA at white empty icon 13:20pm
* 5.060v and 172mA one white bar 17:00pm
* by 22:00pm, battery icon reports fully charged and the DVMs are oscillating backward and forward between the following two states:
* 5.73V and 159mA
* 7.48V and 2mA
The batteries are eneloop 1.2v 750mAh so C/10 should be 75mA. These eneloops are equivilent to those recommended by gmkbatteries.co.uk for a C430HX, and from what I can tell the original gigaset batteries were 700mAh. So charging these at 170mA, is about C/4.4. I then looked at the first C430HX phone again. After it settled down I saw it also oscillating between the same two values. Using a scope, rather than DVMs, I was able to see a 600ms pulse charging with the battery getting a C/4.4 shot of current for 100ms of the cycle. I am not a battery expert so I cant comment on the effects of C/4.4 pulse charging fully charged batteries for months or years.
So I am wondering if it all comes down to the batteries ability to cope with the charging regime. I intend to try getting some of the original gigaset batteries - these super eneloop batteries may not be suited for this application.
해당 답변은 도움이 되었습니까?
점수 2
댓글 6개:
Great detective work @ferg22 - this is so endemic with the Gigaset and their clones that my view is that there's a planned obsolescence involved. It is as if they tuned the charging pattern to the expected life of their 'original' batteries, and that pattern is not good for other batteries.
It really would be an interesting experiment to try a pair of original Gigaset batteries to see if they yield a similar work duration (but this requires dedication and perseverance over time which most of us can't afford).
At one point, I was considering the use of AAA batteries that are directly charged by USB-C connector (like https://www.aliexpress.com/item/10050024...). I actually ordered them recently and will be testing how good they are. Could be a solution other than I am not sure it will work if I supply them both with the same 5V source (a much more sophisticated electronics would be needed, and that was for Gigaset to do from the beginning).
@ferg22 charging is controlled by the telephone, not the charger. Use UNCHARGED NiMH batteries, place the phone on the charger for 8.5 hours, leave the phone off the charger until it is completely discharged before leaving it on the charger again. It has then learned the battery capacity, and only trickle charges after that. Repeat this learning procedure if you remove the batteries. See:
Hibou
@Alain Huett You are correct; the phone controls the charging. However, I could see the batteries were being overcharged and latched onto the charger as a possible cause, given it is labeled a 4v while I measured its output at 6.8v with a 50mA load. But, the charger may only be a part of the issue.
Interestingly, I recently found https://osmocom.org/projects/misc-dect-h... where the section "NiMH battery charge configuration" seems to confirm that the batteries might be being overcharged. I am totally Mac OSX based so I did not even bother to download the toolchain, has anybody else here tried changing the charging parameters?
As mentioned earlier I gave up trying to fix my existing batteries. So, circa Dec 2021 I bought new batteries for every handset, from the site which claimed to sell the exact batteries needed for my models. I have two c430hx and two s79h handsets. Overall the results, after 6 months of use, were disappointing. That said, one of the c430hx handsets, the most used, appears to be working absolutely fine. The other c430hx only reports half charge despite having sat in a charger for days. The first s79h just would not charge no matter which cradle it was on. The second s79h reported itself as charged but ran down very quickly during use.
Based on Alain's and the FAQ's advice I left 3 handsets to go flat and then recharge. The battery icon was red for ages/days, before the phones started beeping and showing the message "charge battery". The battery voltages measured in the handset on load before recharge (LCD on) were as follows
C430HX bigroom2 -> 2.307v
S79H int6 -> 2.398v
S79H bed4 -> 2.371v
I am charging and will report how they fair - it may take another 6 months. In hindsight, it may be crucial, after the removal or replacement of a handset's batteries to let the handset go flat(below 1.2 per cell) and then fully recharge for over 12 hours.
댓글 1개 더보기
댓글 달기
Had the same. Just to try if your rechargeable batteries need refreshment - replace them with regular ones and try to switch handset on. For me it worked.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Thanks for your answer.
I did put in new rechargeable batteries, in both handsets, some months ago, but the problem remains: sudden complete shutdown of the handsets during a conversation or during the dialling.
Now I put in non rechargeable batteries and for the moment I do not have the problem anymore.
Thanks for the hint, I wonder how long the batteries will last….
Robert
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Works OK with non rechargeable batteries, but after 16 days of usage I had to put in new ones. So this was no real solution. It indicates however that around the 1,24V per battery, the handset suddenly shuts down.
댓글 달기
귀하의 답변을 추가하세요
David 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 24
30일 전: 115
전체 시간: 19,116
