주요 콘텐츠로 건너뛰기
The NeuTab N7 Pro tablet has a front and rear facing camera, 7-inch display, and is powered by Android KitKat.
I cannot download any media/applications on my NeuTab N7 Pro?
Every time I try to download an application on my NeuTab N7 Pro it starts downloading, but immediately stops. It says "not enough space". How do I fix this problem?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
Hey Robsander,
Your device is out of memory, so you need to clear up some space.
First, go to your settings menu, then select "Storage". From here you can see how much space is available on your device, and what's taking up the most space. You're probably going to need to go through your apps and delete extra apps you don't use. You can do this by selecting "apps" from the storage menu, then by selecting an individual app from there.
Be aware, many apps that came with the device can't be uninstalled, as they're needed for the android system.
If you need help with anything else, check out the troubleshooting page.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
Robsander Carrasquero 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 381
