주요 콘텐츠로 건너뛰기
The Skullcandy Air Raid is a wireless portable Bluetooth speaker released November 15th, 2013 which streams music from any Bluetooth-enabled device.
16 질문 전체 보기
Device is paired (post-reset) but it wont play any sounds? :(
I reset my device (plus sign with center button). Pair my ipad, but all i hear is a very slight static/hissing/white noisish sound despite the music runnning on the ipad.
Help? :(
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Hi,
When you reset the speaker, did you also remember to forget the Air Raid in your Ipad Bluetooth list before you re-paired it with the speaker again?
Try a soft reset again as per the following information and see if it resolves your problem.
Soft Reset:
Hold Volume + and the center button for 5 seconds to reset the paired device list in the speaker.
Remove Air Raid from your device: Go in to pairing settings on the device and remove or ‘forget’ Air Raid.
and then pair again.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
I pressed the plus and minus sign and won't turn on anymore. Please help!!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
annawahlsten 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 221
