주요 콘텐츠로 건너뛰기
Small media streaming device that plugs directly into your TV's HDMI port. Originally released by Amazon in November 2014. The latest version comes with a voice-activated remote.
Powering my fire tv stick off my TVs USB port
Is it ok for me to power my fire tv stick using the USB port built into my television? The instruction manual says not to but I have been powering mine this way for about a week and have not had any issues. Will using the USB port on my TV affect the performance or damage my fire tv stick over time?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 8
댓글 12개
Is this the same thing that fried your iPhone?
No, I am never using that speaker again. I immediately discarded it.
Don't do that. Fix it!
I attempted the usb port today and it bricked my TV. It would not power off. I had to turn the breaker off from the sub panels in the basement. Luckily, it powered back on, once I flipped my breaker back on. TV is no longer a brick, it works again.
It works great, Ived done this for years. With a couple different versions of sticks and different TV's no issue what so ever. The stick is just a device that is powered by USB... Most TV's have a standard USB port.. it works
댓글 7개 더보기
댓글 달기
답변 9개
선택된 해법
Hi,
According to this link,( http://www.amazon.com/gp/product/B00Q50X... ) it seems that the Fire Stick requires >900mA to work effectively. You may wish to check what is printed on the supplied power adapter that came with the Fire Stick as regards the output current to verify this. It should be greater than 900mA (it probably is 1A).
Your TV's USB port seems to be supplying at least this amount of current as you say that there have been no issues.
An issue may (I stress may only) arise if for example you have the Fire Stick being powered by the TV's USB port and you connect another USB device (if you have that many USB ports on your TV) and find that it doesn't work or that the Fire Stick then also doesn't work because the total power that is being supplied to the USB ports is not enough for both devices. This is only conjecture on my part but the Fire Stick is drawing more current than the average USB device.
To be sure you would have to check the TV's specifications and see if you can find out what each USB port's maximum current output is.
As to what damage may occur to the Fire Stick by powering this way. In a way it may be a safer option than using the supplied power adapter. As long as there is enough current being supplied by the USB port (see above proviso) it should be OK. If there is a situation where the current is less it could lead to possible 'data corruption' in the firmware of the Fire Stick if the power was fluctuating.
By using the TV's USB port, in effect the TV is acting as a power surge protector for the Fire Stick. In the event of a wall outlet power surge hopefully the TV will bear the brunt of it and the Fire Stick will be spared. Whereas, unless you have the power adapter connected to the wall outlet via a surge protector there is no protection whatsoever for the Fire Stick if a power surge occurs.
My only suggestion to be really sure of not causing any problems is that if you wish to remove the Fire Stick from the TV is that you turn the power to the TV off before you remove the Fire Stick, rather than removing it from a powered TV.
이 답변이 도움이 되었나요?
점수 8
댓글 5개:
Thanks, I just wanted to make sure that it wouldn't mess up my firestick.
I'd be more interested if it would mess up my TV rather than the fire stick itself! A TV costs a lot more then a fire stick.
seems like older TV’s are not meant for this - i burned out/corrupted a fire stick by plugging in to the TV’s USB Port - it was marked “Service” which probably means it’s only for data (mb tv firmware updates) - it was a samsung tv from maybe 2005 ..
When i earlier plugged same fire stick into a 2017 TV the firestick worked fine and a 6 inch usb wire was perfect -
- btw amazon or any online electronic retailer sells any size micro usb for about 2-3 dollars - the “firecable” is a big waste of money - for less than price of “ firecable “ you can buy a 6inch long micro usb cord with a lighting adapter included ( 8 or 9 bucks) that comes off but stays on off to the side with a little rubber holding piece) so u can charge iphones too - just search “micro usb to lighting adapter” great for portable chargers to add extra charging capabilities, like vapes, bluetooth speakers, headsets all that micro usb stuff
The tv USB port provides more than enough power for a fire stick. The reason they don’t want you to power your stick this way is due to the device completely shutting down and not receiving updates automatically...it’s also a PITA having to go through startup process if you have a jail broken device every time you turn your tv on
MY old tv's and the New smart tv all power my western digital 1 terabyte passport. watch movies on them all the time. It has to use more power than the fire stick.
댓글 달기
This firecable works, BUT be aware!
I've been using a firecable for a few months and it DOES work to power my firestick right off the TV usb port. The only problem is you have to access the back of the TV for this cable to supply power to the firestick. My TV is mounted in an awkward position so it was difficult to access the back of the tv. You have to connect the cable to the firestick then the other end to your USB port. This was difficult for my setup. Once I plugged both sides in and pushed my TV back into position it was all set.
The cable is a thick gauge and does an excellent job of drawing stable power to the stick. I have one stick with a cable in my living room (this is where I had trouble getting to the back of the tv). And another one in my bedroom. We use both tv's/ sticks with Netflix and a few other services as a daily driver and I haven't had a single problem with my sticks or the cable over the past few months. I really like it because I don't have to run an ugly cable down the wall to get power.
Again just make sure you can access BOTH your USB & HDMI ports on the back of your TV or get some help getting to them. Good luck! Here is the link. [http://firecable amazon|https://www.amazon.com/dp/B06XZBWR33]
이 답변이 도움이 되었나요?
점수 3
댓글 달기
Fire tv stick need 0.15A
Once I used my phone charger after that use of 1 or 2 hours till now my fire tv stick is not working and I bought new one, with its own power cord and adapter it works good.
Thanks
이 답변이 도움이 되었나요?
점수 2
댓글 달기
I used two do this and then it fried not one, but TWO of my TVs. Had to send them to repair and it was more expensive than I expected. The Firestick is OK, the TVs are not. Never doing it again.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I'm working on this too. I have the 4k Firestick, a NES Classic, and a SNES Classic. Everything I've read indicates that I should be able to power them via a powered usb hub (one plugged into a wall). As for plugging just the Firestick into the tv, there is a product out by Mission that allows you to do this ($20 on Amazon https://www.amazon.com/dp/B078KSHVCS). Hope this helps.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Just purchased two fire sticks, one as a gift for my sister. Installed hers first. When trying to use the TV’s USB for power we got an error msg so we plugged the stick into the wall. When I installed the new Firestick into my 8 yr old Samsung TV we got the same msg regarding the USB for power ‘not enough power or low power’. Instead of plugging into a wall outlet I used the USB on the front of my DVR. Still got that error msg but it’s working just fine. It’ll be easy to unplug because front of DVR is easy access. Double checking power specs on that USB port once ATT can confirm for me.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I would rather use power from an outlet to be safe and sure. But I do not like the idea of wear and tear on adapter plug via plugging or unplugging it all the times when in use or not in use. And I do not want to leave adapter connected to power source all the time. Remedy: I got an inexpensive surge protector solely (nothing else on it) for the adapter; the surge protector is within comfortable reach to turn power on and off.
댓글 달기
No one seems to be mentioning the fact that when you use the usb port from your tv you shut off the tv and the firestick, which is awesome. This works great for my one tv a newer one, the other has a tendency to be slightly less power and acts up every once in a while. I wonder if there is a booster i could use to increase the power just enough to keep it from acting up. Any Ideas?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
what if my tv doesn’t have a usb port just a hmdi?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
As commented in my post, I prefer not to use the usb port on my tv anyway. So, per my recommendations…I would plug the firestick power adapter end into a wall power outlet or have an inexpensive surge protector connected to it. Given those options, I would use a separate surge protector (only for the firestick) that could be (if possible) conveniently placed to turn stick on and off via the surge protector. I do not recommend keeping the stick powered, when not in use. One reason…over heat. Another reason…if tv is off, the stick remains on, and anything your vpn protects…better be working. Because some vpn’s drop off or leak.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I had my firestick plugged into my 2008 Samsung plasma tv for 3 days and now my tv isn't working. Sound but no picture. Flashing green light inside back of tv. Does anyone know what could be wrong?
댓글 달기
답변을 추가하세요
Kris 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 50
지난 30일: 301
전체 시간: 282,331
