Can I upgrade from 30GB to 80GB hard drive?
Can I upgrade the hard drive from 30 GB to 80GB with an iPod Video?
좋은 질문 입니까?
좋은 질문 입니까?
yes, but you will need a backplate from an 80GB model, because the 80GB drives are thicker than the 30GB drives, but other than that, the drive should work fine. But do make sure that the 80GB drive is from a 5th generation video, not a new iPod classic, this isn't a major problem, more of a precaution.
해당 답변은 도움이 되었습니까?
Here is the total list of what you must replace:
*60/80 gb rear panel
*60/80 gb headphone jack (it's about 1/4" longer
to reach around the thick hard drive)
*60/80 gb battery (longer to reach around HD)
*60/80 gb rubber bumpers (taller to protect logic board in thicker casing)
good luck!
해당 답변은 도움이 되었습니까?
Correct me if I'm wrong, but since the 80GB iPod Classic from 2007 is the same thickness as the previous generation, wouldn't its harddrive fit without need of other components?
해당 답변은 도움이 되었습니까?
.... You're absolutely right. They also use the same hard drive cable, so replacement is an issue of restoring, in theory. Good call!
24 시간 전: 0
7일 전: 3
30일 전: 6
전체 시간: 8,833
